How To Replace Leaking Rear High Pressure Power Steering Hose 1999 996
"Now pat yourself on the back and think twice before emailing Porsche for a service quote."
Don't forget to smile as you check your wallet, pocket, or bank acct. balance (wherever it is that you like to keep your cash!)
I have this same issue, but on the low side, or return line. Do you know if the fitting is set up the same as the high side? I bought both the flexible hose from the pump and hard line going forward to the mid-chassis connector as used parts off a 2004 Cabrio. I did not know to look for or ask the owner of the parts car if he had seen a teflon ring in the low side fitting. Either it was never there or it is missing. I measured the groove and it is only 2mm wide, so I don't see any way that a teflon ring plus an o-ring fits inside. Porsche wants to sell me the complete fitting for $150. Ouch. Maybe the low side only uses the teflon ring. Has anyone repaired their low side p/s fitting that can help me out?
If I have to cut off the male side, where do I find a replacement for it? And do I need to flare it, or do you or anyone know of a male compression fitting that fits into the stock Porsche female side. The Porsche dealers only sell the complete rear line, # 996-347-539-53 which connects to the front line section, just in front of the right rear wheel, under the chassis. I have to remove the engine to install it.
