Plug Tube O-ring Grease...
The small tube of 'Porsche' grease for the spark plug tube o-rings cost about as much as a set of tubes. Is there a standard grease out there that works as well, a moly based grease or other high heat version?
O-rings. Might want to take them off to apply in case they roll when inserted.
At the end of this thread is a cheap method I came up with for getting the tubes out....https://rennlist.com/forums/996-foru...-change-2.html to add to the list of removal techniques.
I'm sure the stuff listed will work. The manual actually recommends tire mounting grease as the alternative. I just asked tire guy for a little and he gave me a glob. Apparently it lubricates initially during installation and then gets tacky to prevent movement.
