Coolant refill procedure problem
I have just gone throught the procedure described in the Porsche workshop manual and in some threads on the internet. They state that fuse B1 has to be removed if the car has tiptronic so that a shut off valve stays open when the car is started and revved up to remove air from the system.
Temperature and revs have to be monitored. Problem: fuse B1 also controls the instrument panel (and the diagnostic socket), so impossible to monitor temp and revs with the fuse out.
Someone must have had the same problem. Help!!
Car is 996, C4 cabriolet with tiptronic
Not sure if this is helpful but did you use an airlift before refilling? I don't have tiptronic but when i used the airlift after replacing the waterpump and thermostat (and throughly draining the system) I had very little air. In maybe 200 miles of driving I added less than 1/2 pint of fluid to top off and havent added any since.
If so, you may not have a problem.
Cardigan Millionaire
What kind of Mileage do you have on your car? Why are you refilling? Porsche coolant is supposedly a life time coolant and should not have to be changed in a regular interval. I did mine once, but only because I had a fitting break
18000 miles! Rubber hose sprung a leak, actually a t-piece came apart where the tiptronic cooler pipe comes off the main back to front pipe.
Most of the coolant drained out via the leak.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
+1 good advice I did it that way plus when running car I had heater on I think to let the valves open up thermostat to open it will cause the red temp warning led to flash let car cool down properly then topped up
