99 C2 Cab Wheel size
Hi Guys
there is a nice set of wheels/tires on ebay,here are the specs,im confused about all the specs and if these will go on my car,want to be sure before i buy,any info would be appreciated Thanks
Albert
Rim Brand: Factory, OEM Rim Width: 8/10.5
Section Width: 235/265 Offset: 57/60
Aspect Ratio: 40 Number of Bolts: 5
Rim Diameter: 18 Bolt Pattern: 5x130
Tire Brand: Continental Tires
Albert
Hi Guys
Albert
Albert
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I have a 99 C2 Cab with 18" factory Turbo Twists and the offsets are 50 front and 65 rear. My wheels are 7-1/2" wide front and 10" rear. The 8" and 10.5" widths you mention should be no problem and the tire size should be OK but I'm not sure what these wheels came off. Maybe a Boxster with those offsets.
Former Vendor
That's a narrowbody 996 fitment. You'll have to add 18mm spacers to the back to make them work on a Boxster/Cayman. If used on a 996 a 7mm up front can't hurt.
