Puddle of coolant on garage floor
Came from from the Iron Maiden show last night (yes, they rocked!) and noticed a puddle of fluid under the 996. My heart skipped a beat as I thought it was oil but when I examined it closer I found it to be coolant.
A couple of days ago I got the "low coolant level" warning but then it went away after I turned the car off and back on again. I thought it was a fluke and even in our hot temperatures the last few days the car stayed within normal engine temps when in traffic.
So I got under it and it appears the AOS has coolant on it and so does an area close to where a hose connects to the coolant tank. The fluid appears to have dripped down through an area to the right of the rear driver's side wheel but a little bit ahead of it.
I took some photos to show how things look there but as you can imagine it is tough to get a good shot.
So my question now, is this the coolant tank? Is it the AOS? A loose hose clamp? How can I tell what it is so I can address the right issue?
Well even if I wanted a tank it doesn't seem they're available in this country right now!
Called several dealers and they are out of stock. My local dealer said there was a recall on them which is why old ones were pulled off the shelf. They are doing research and will call me back.
I filled the coolant back up and went for a drive, everything seems ok right now but I also have an autocross scheduled for Sunday. Hmmm, worth taking the chance?
Charles - thanks for the offer but I guess not this weekend!
Ugh, that's not what I wanted to hear since this is my daily driver.
Any temporary fixes for this thing? I remember on my 944 the coolant bottle sprung a leak but I was able to temporarily fix it until the part came in by using some plastic epoxy.
I'm going to try to call around to some other places as I do want this fixed ASAP. Guess I'll have to see if the wife let's me use her SUV for the autocross!
Unfortunately not. The coolant cap was replaced about a year ago so I've got that part covered. That is unless it went bad again. But it appears the whole leak came from the back of the engine which really points to the tank. Any way to test the cap individually?
Now on to a rant...Why put the coolant tank so close to the components of the car that create heat? Why not put it up front with the radiators? Oh well, can't do much about that now.
I found one! Getting it sent out on Monday so I can't install it this weekend but I'll have one soon enough. Thanks for the suggestion though.
