Fister D's Arrived! Now..who should do the install?
#32
Bumping this thread as I am about to start the removal to ship to Fister. I hit the bracket bolts with PB Blaster this morning; anything else going to need a shot of PB Blaster or will the rest of them come out pretty simply?
#33
This is one of the easiest things to do. 3 13mm nuts and 2 bolts that attached the can to the cat.
Also found this
https://rennlist.com/forums/996-foru...lp-needed.html
If you do a search there are tonnnnnnnss of threads like this.
Also found this
#34
Clamp nuts are SUPER rusted. Applied pb blaster this morning but so far nothing is budging. 17 mm ratchet appears to be slipping a little bit, definitely not a tight fit. Might have to bite the bullet and take the car to a shop to get these loosened. Don't have access to a torch.
#36
Ok, there is a 0% chance I am going to be able to get these off on my own. I've brilliantly managed to round off the one clamp bolt and I reached my hand up to the area where the 3 13 mm bolts are and those feel as rusted as the clamp bolts were when I started.
So, what are my options for removing these cans and shipping them to fister? If I take it to a shop for them to remove them I will be muffler-less and don't think I can drive it home that way as fun as that sounds.
Ideas?
Ideas?
#37
Do you know someone with a decent air compressor and cut tools? If so you could take the bumper and heat shields off and cut the 2 bolts (not the 3- 13mm because those are weld studs) that hold the can to the muffler bracket and cut the bolts by the cat.......I guess you could use a sawzall for that matter. Replace with new hardware.
#40
Wtf. Cut the nut clean off and the clamp hasn't moved a bit. This project has now reached the "I will be successful even if it means I light the car on fire and burn down my house" stage.
#43
Bolt has been cut off, driver's side clamps are loose. 13 mm nuts are soaking in pb blaster. I'm having trouble getting a ratchet onto those nuts; any tips on getting to them? I'm assuming it's just being careful and taking my time but if there is a trick let me know.
#45
I have 9 of the 10 nuts loose and the passenger side muffler off. I think I am at risk of stripping the nut on the stud farthest back on the drivers side. Grrrrrr..... So close.
