Help 1999 cab Nut broke in windshield frame
hi guys
hope someone can help with this,the interior light that bolts to the windshield frame and is also the piece that the latch on the soft top locks into,well one of the nuts split open so i cant screw the bolt in on that side,so when the soft top and also my hardtop is locked in it has movement and rattles alot,the nut is inclosed in the windshield frame so there is no way to just go get a new one and put it in,any ideas?,has anyone had or seen this problem?,heres a couple of pics so you know what i mean
Albert
Albert
Wow. Not seen that before.
Bad luck
The only thing I can think of as a quick and dirty inexpensive fix would be to use some gorilla glue or no nails equivalent and hope it holds the screw in place.
I'm sure my rudimentary fix may get some criticism on here and rightly so
But it's all I can think of.
Good luck
Jack
Bad luck
Good luck
Jack
Nice write up for the DIY. My center piece came loose, I think it happened over time but I just noticed it the other day when one side came completely loose. Fortunately my nuts were not split, just had to reinsert the lots and tighten them down. Not the rattles along the frame that I had been having are comp,etely gone.
