Does PSM need to be recalibrated after installing PSS9s?
Are the yaw and tilt sensors repositioned by the lowered suspension and different F-R height ratios, requiring the PSM to be "re-zeroed"? Never seen anything mentioned about this with all the lowered 996s out there. SEEMS like it should be.
After lowering mine. I had to recenter the wheel sensor.
After the install and alignment (which you should after the install) it is recommended that the steering angle sensor be recalibrated. This is part of the PSM, so if you don't have PSM then you don't need to do this. If the sensor is miscalibrated you won't really know it but the PSM won't function properly.
You need a PST2 or the newer Porsche system, or I believe tha latest version of the Durametric will do this.
You'll be sent a warning every 15 min while you are driving.
Yes, I have PSM, which is why I asked. I still have the old tires I hate on the car, while seating all the new rubber, and while front camber is good (put on new x74 upper strut mounts), no such thing for rears, (but did put on new RSMs), so rear camber is a little extreme, and I notice PSM kicking in easier than before lowering. Will be putting on new PS2s this month and getting alignment, and just wanted to make sure I need adjustments made, as obviously not all shops would have a PST2, nor would they know what was needed.
