loss of power during acceleration!
+1 on the maf sensor. A cold air intake soaked in oil can thow all kinds of codes. Under hard acceleration the engine is pulling in a on of air and often times oil from cai as well. That oil will gob up your maf/map sensors. If that's the case you usually can clean the sensor and be good to go
If it is the latter two items the repair can run into several thousand dollars. (MY 02 Boxster had its passenger side VarioCam solenoid/actuator replaced some months ago and the cost came to around $3K. The 996 IIRC has an easier to get out solenoid which may (May?) help keep the cost down.)
This problem won't get better on its own so you want to get it professionally diagnosed and fixed.
Sincerely,
Macster.
