What do you think of my fuzzy magnet?
I have changed my oil every 5k miles since 36k miles.
Maybe I haven't been clear enough. My car has over 117k miles and this is the first oil change(5k miles ago) since I've installed the magnetic plug. So what you see is 117k miles of metals finally being caught by this magnet over the past 5k miles.
To the OP:
I wouldn't worry too much about the debris on the magnet until you check the oil filter. If the filter has a bunch of metal in it then I would be concerned.
At your next oil change, I would remove the sump plate and see what you find sitting in the bottom of it. Check the oil baffles to make sure they are ok, clean the oil pump screen free of debris if there is any, and then put it back together with fresh oil. That's what I intend to do during my next change.
My LN mag plug always has what I would describe as "metalic hairs" on it. Before I rebuilt the engine the hairs were thicker than after the rebuild. Your debris is thicker than I have ever had but I can't judge the size from your photo. If you touched it with your bare finger is it smaller than a salt granule? I would very carefully inspect your oil filter with a magnet & repeat all this in 1-2 thousand miles including removing sump plate.
Former Vendor
This is ferromagnetic "fuzz". It is attracted to the MCD of the IMS Guardian but that amount more than likely would not have triggered an IMS Alert. The IMSG may have begun to emit a very faint squeal, thus telling the driver that the engine had ferromagnetic particles present. These particles can mean you went too long between oil services, or that you have elevated wear metals in the engine. The difference between a full blown IMS Alert and the sound that is emitted when ferromagnetic fuzz has accumulated is like night and day. I designed this into the system from day one.
The IMSG was designed around a 5,000 mile oil service interval, specifically. It is very critical that these service intervals be followed.
Based on what I see in this picture the oil would be about normal for an 8-10,000 mile service interval, but the material looks to be heavily laden with the materials that we typically see come from worn camshafts or lifters and even timing chains.
I'd clean that magnet and run a short service interval of 2500 miles to see how much accumulates and then report back. Or you can monitor the condition from the driver's seat using my IMS Guardian system :-)
This is ferromagnetic "fuzz". It is attracted to the MCD of the IMS Guardian but that amount more than likely would not have triggered an IMS Alert. The IMSG may have begun to emit a very faint squeal, thus telling the driver that the engine had ferromagnetic particles present. The difference between a full blown IMS Alert and the sound that is emitted when ferromagnetic fuzz has accumulated is like night and day. I designed this into the system from day one.
<removed by author>
