NA-TT 996 3.4 build
#31
JR Gordon, thanks for answering my question. Does that mean that 3.8 is attainable with a 3.4 engine....provided you use a different crank, rods, and cylinder sleeves?
#32
I want to squeeze a little more power out of my 996. When I say I little I'm talking somewhere around 100whp more. Has anyone on here built up their own turbo kit to use on the early 996 that would like to share their thoughts? I'm thinking of picking up two KKK K26 Turbos, Mazda 323 intercoolers, piping and what not just to get started. I'd also like to know if anyone knows of a good location to tap into for my oil feed lines.
#35
i don't know how far the OP got w/ this project idea but i'm about 1/2 to 1/3 of the way there.
What I do have is this:
3.4 engine getting iron sleeves w/ larger bore (either 99mm so i can use facotry 997 head gaskets or 100mm w/ custom headgaskets made)
3.4 crank (custom grind stroke slightly longer than the 3.6 996 crank shaft)
3.6 pauter rods
heads are getting 3 angle valve job with port and polish
EBS springs w/ titanium retainers
Dual pump fuel system for e85
single turbo setup w/ t4 60-1 (will posibly change out to a gtx40 or gtx42r)
ARP2000 Head Studs
ARP2000 Main Bolts
Whats up in the air is this:
piston - arias or je (both ceramic/mly coating), 9.5:1 or 9.0:1, 99mm or 100mm
camshaft (stay with stock or get a custom grind)
clutch (twin metalic disc aasco/tilton)
Stock TB 74mm or do the ipd plenum with a 997 GT3 TB 82mm
3.6 pauter rods
ARP2000 Head Studs
ARP2000 Main Bolts
