NA-TT 996 3.4 build
I want to squeeze a little more power out of my 996. When I say I little I'm talking somewhere around 100whp more. Has anyone on here built up their own turbo kit to use on the early 996 that would like to share their thoughts? I'm thinking of picking up two KKK K26 Turbos, Mazda 323 intercoolers, piping and what not just to get started. I'd also like to know if anyone knows of a good location to tap into for my oil feed lines.
Plumbing is the easy part compared to ecu tuning and management. I've built a half dozen turbo kits previously for BMWs, Honda, and Subarus but I will not touch the Porsche motor. Too expensive to replace and the ECU is relatively unknown to tinker with.
Please don't go the ghetto route with bigger injectors and rising rate afpr. Even then you still have to find a way to adjust timing.
Best of luck if you're brave enough to go down this route.
Why not just buy a turbo car? One problem with trying to turbo charge a regular 996 911 is where do you put the aftercoolers?
I've seen high mile turbo cars for under $30k and cars with mileage between 30-60k in the $30s and $40k range.
Byprodriver, I also thought that the 3.6 crank was the way to go, if you were rebuilding a 3.4 engine. I believe that I read on Jake Raby's site or in one of his posts, that the 3.6 crank will not work in a 3.4 engine because the oil passages are not compatable. Did I misread his information? Do you know something different from personal experience? Thanks for any information that you can provide. It would be nice if we could buy a stronger aftermarket crankshaft for our cars to allow for greater displacement.
The ECU stuff is the easiest part, just reflash tuning on the dyno.
The hardest part really is the intercooling, a water to air setup will be the logical choice, maybe a PWR unit.
Lol, care to explain?
Do you know how many tuners/people have the Porsche ECU figured out? You do realize that tuning on the dyno mainly gets you WOT conditions and lacks the granular level to do part throttle mapping and daily driving conditions such as temp and humidity. Granted if you leave enough of safety buffer in your tune, these areas might not have that much of effect.
Have you ever tuned a car before?
I can tell you the majority of the cost of a "well" tuned turbo kit is in the r&d tuning area which takes the most amount of time(assuming factory ecu is used).
I agree with some the plumbing and Turbo's is the easiest and the weakest link is the tune and since it would be custom it will be pricey and a selected few tuners can do it. Building it was fun however if I did it again I would just buy the kit. GL
https://rennlist.com/forums/996-foru...problem-s.html
Not worth it and I completely agree in buying a kit the first time around for some thing like this.
If only there was a plug and play version of one of the many "auto-tune" ecu's out there for our cars... Then we still have to deal with the anti-theft and coding issues as well...
Yup, I have tuned a car, using an aftermarket ECU, my flatmate has a dynapac hub dyno.
Its the easiest part because you just pop the car on the dyno, and enter values into timing and fueling tables plus other parameter tables like excel fueling and over run and rev limit and you get the point... reflashing an ECU will run around $2k depending on he process (live mapping versus save and run incremental changes mapping). Or about the cost of one of the two new turbo's
Nothing wrong with buying a kit if you cant do the work yourself... the cost is unreasonable though in my view.
I have not tuned a 911 before, only a 944 turbo, Supra, Levin, and Trueno. When did you start tuning 996's? Keen to hear your experiences.
