PSE cutout removal with pics
#61
I was about to say "no switch, no wiring", but then I took another look based on some information in this thread here on Rennlist. I have a blank where the switch would be -- if it were on the left that is. Lo and behold, on the RIGHT side there is a blank but with a harness connecting to the back. In other words I have everything except the switch itself. Prod month "2002-06-01" and "XLF" on the frunklid tag, so this is how it came from the factory. An odd duck I guess? Although from other threads on here it appears as though the early 996.2's might have had, errr, variations in how this was installed at the factory.
I'm off now to place a small order...
#62
Awesome! So glad it was an easy solution for you! Its nice to be able to turn it off when you want, problem is I never want! Did you put the switch on the left or right side?
#63
Thanks again!
Dranon (10-22-2021)
