My turn IMS pic
#31
Former Vendor
On another note:
We saved this one this week. Zero IMS failure symptoms, no noise, no oil leak- Pulled the flange as standard procedure and found this. This was a dual row also, if it was a single row it never would have gone this far without grenading.
#33
Jake....Or how many miles were on the clock when you checked this one out? Also were there any fine metal found in the filter? Also why were you checking it in the first place? There has to be a better reason reason the 'Just standerd procedure'. Thanks
#35
Ok, I understand that it happens, but what about Oil analysis? I change the oil now at 5000 miles, 0-40 Mobil One. I have Blackstone do an oil analysis, nothing shows as yet at 43,000 miles. Do you think that this procedure will do at least as good a job as the Guardian addition? After all a Mass Spectrometer will show minor levels of wear from races , at a level impossible to see by visual inspection or a device meant to attract and warn of excessive wear. I am convinced it takes at least five thousand to ten thousand miles for the bearing to go from showing minor wear and the oil analysis showing excessive levels of wear to the failure point. I know that probably isn't documented and maybe changes in each circumstance but i still think Oil Analysis is way better than anything else. What say?
#36
In my opinion The Guardian is just a plain common sense good idea regardless of whether the concern is the IMSB. It dawns on my mind now that all high-end automobiles where the stakes for potential catastrophic failure, that could lead to complete engine or gearbox failure, should include such a device as a feedback system much the same way they do by providing idiot lights that tell operators to check the engine for less critical parts like failing O2 sensors, and or to change oil or warn of low oil.
Again... just my opinion.
