Longer seat belt receptacles for 996?
Has anyone put in longer seat belt receptacles to accommodate GT2 or aftermarket seats in a 996?
There are some longer ones made specifically for the GT2 seats in the 997 and I could really use them for my OMP seats. I just don't know if the little wire will connect up correctly to the 996 and I can't find any part numbers specific to the 996 for longer seat belt receptacles.
The ones I've found are described here:
https://rennlist.com/forums/997-gt2-...t-install.html
They are over $100 each and I don't want to waste money if they won't connect up right
Admin
I have them in the 6GT3 with Recaro seats.
They are great (for any bucket seat with hi sides) because, you can pass them through the seat's side opening and have a perfect fit for the 3p belts.
(The Euro GT3 seats work with the std 996 ones.)
The connectors of the 7 are different and if you want to connect them you have to reuse the ones from the 996 buckles.
But, I tried it, and they do not communicate well.
The 996 ones are an open circuit that closes when you connect the buckles (giving the warning light) and opens again when the belt is secured.
(Note that on RoW cars we only have one connector for the driver's seat and that simply leaving the connector unplugged gives no warning light. Perhaps US cars (that use warning connectors for both sides) are different and compatible with the 997 buckles)
But, I tried it and, they do not communicate well.
Thanks. Think I'll start with one and see how it goes. Struggling with these shorty receptacles every time I get in the seats just won't do.
Bringing back an old thread here that didn't seem to come to a conclusion. I am in this same scenario, looking for longer seat belt receptacles to work with my Sparco qrt-r seats installed in my 2003 996tt. The stock belt receptacles have 4 wires, I bought some longer 997 receptacles, but they only have 2 wires.
Has anyone come up with a solution?
I bought an extender for my 928 as the female portion is almost hidden
https://www.seatbeltextenderpros.com...belt-extender/
maybe not the route you want to take, but it's certainly an option
