996 Turbo new exhaust with carbon-fiber tail-pipes
Hello I'm new on this forum & I just mounted new exhaust for my 996T. So I decided to make my first post with this excelent update!
First of all sound is brutal & performance of the car is more than noticeable!
For beging here are some quick pics but in short future video & some dyno numbers are also comming...
There's no brand for this exhaust. It's custom made from some local guy who worked at well-known exhaust company on porsche department. He also made carbon fiber tail-pipes. Yes, I was also wondering if they will discolor or get burned but he told me that carbon fiber is made with special heat resistant epoxy resin with process called "vacuum infusion" and cured in owen... On the inner side CF "sleeve" there is also temeperature isolation which prevent heating CF and at the back side where CF sleeve is attached there are also holes for coolling the space between inner tube and CF sleeve during ride...
I run this exhaust aprox. 1 month with no color-changes on CF.
Everything is realy made with perfection and also tubes are TIG welded and during welding tubes were filled with gas(argon) to prevent weld oxidation inside the tube. So at the inner side of the tube welds are totaly flat.
