Just complete the AOS replacement
I just finished the AOS replacement and let me tell you that it was easier then i tough at first..
Everybody scared for the (intake 6th bolt) but once you took out the throttle body and i also took out the alternator it was really simple and easy.During the process i had to do the job by 2 times and the second time it took me just 30 minutes to took out the alternator and the intake....believe me it is really easy to do.The trick is to use your two hands .....one of each side of the intake... that way you can place the ratchet easily
I have been surprised when i realized that there was missing some vacuum hoses and there was supposed to be a 4 way splitter attached the vacuum tank but someone before me replaced it by a 3 way splitter and did not connected the vacuum of the change over valve....just to understand how the vacuum circuit works i passed more then 2 hours in this site but finally received all the info from OZ951...thanks to you guy...that was great.
While i was there i had the alternator rebuilted ($150.00) and the starter ($60.00).I also replaced almost all the vacuum hoses ($15.00) and changed some coolant hoses(100.00) all parts from the Porsche dealer.
I also cleaned all the engine replaced the coolant and changed the engine oil.
If you ever decide to do the job just an advice...take care when you have to split hoses...they are old and believe they will brake.Of corse the vacuum hoses are cheap to replace but the same will happen if you ever decide to replace some coolant hoses....they will also brake...it is hard to believe how supple rubber from new hoses is and the old one are stiff...
Now the engine run like a champ with no more oil leak.
The old AOS was cracked and leak oil that is why i replaced it.
All and all it took me almost 10 to 12 hours (including cleaning) to perform the replacement but now that i know how it works i could easily do it in less then 5 hours.
Robert
911 2000
I have not come across this recently but when I was learning what little I know about cars a tech told me it was not unknown for someone to replace one maybe both radiator hoses but ignore the heat core hose. And a heater core hose failing is nearly as bad as a radiator hose failing.
So he said that if I found one bad hose, or questionable hose I should replace all hoses, even those little bitty ones at the heater core.
These cars not only have short hoses at the engine which connect the water pump/engine to the coolant pipes that run under the car to the front but also short hoses at the front of the car that connect the coolant pipes to the radiators and maybe a hose or two that connects the coolant tank to the engine.
Sincerely,
Macster.
