Bent Wheel advice
Bent Wheel advice
Had my wheels "road force balanced" to take out a vibration at 70mph and they found one bent rear one causing the problem. I've put 10k miles on it since I bought so its not a big deal but my OCD won't let it go. So, I can't find a reasonably priced used wheel (think they are called Carrera Classics) on eBay, three dismantlers so far, or in the classifieds here so am considering the Victor Zehns. Here are the questions:
1. Would anyone have one 18x10 to fit a NB 2003 they would sell?
2. Would those who have the need for winter wheels be interested in the old ones for cheap since they are obviously drivable or should I just chuck the bad one and sell the good three?
3. The Victor site lists only 18x11 for the rear Zehns. I run the 295/30's on the rear with stock suspension. Consensus from searches seems to be that this will pose no problems. If anyone can give me recent experience with this combo I would appreciate it.
I would post a pic but site won't let me grab photos from iPad. Not sure what's up with that. Wheels are as seen in my avatar.
Thanks in advance for any info.
You do understand that you can fix a bent wheel, right? It's usually about $150, and works great (assuming it's not a major bend). Check your local area but I know Wheel Wizards is in CA.
http://www.wheelwizard.com/
-Shawn
-Shawn
Actually, did not so thanks. Will look into. Another buddy referred me to newwheel.com but they don't have the 18x10, only the fronts. They'll buy the bad wheel for 165. Their sell price when they have them available is rediculous.
I had a wheel fixed locally (BBS Sport Design, rear) for $175 - 2 piece wheel. Spec Wheels in Commerce City CO. Came out looking like new (it had curb rash and bent spot).
I've had countless bent/cracked wheels restored over the years. I've never had a repaired wheel re-crack or bend in the same place.
In California, there are quite a few reputable wheel repair shops that should be able to fix you up pretty quick for a reasonable amount of money.
What part in CA? Seems like you are So Cal
I have my local guy in Walnut Creek - Rite Way Wheels - They do some amazing work on bent wheels and refinishing. I had recently an incident with the tire shop who installed my CTT wheels so had them refinished. They look like new now. Oh, he found out 2 of my wheels were bent
Thank you all for the tips. I should change my generic "CA" location to Los Gatos. Thanks to francars. Will get in touch with Rite Way in the Creek. I am up that way weekly.
Also appreciate everyone passing on the confidence in repaired wheels as to my reasonably mechanical minded head, I don't get how they do this on what seems like a fairly brittle chunk of metal but have confidence in the advice given here. Will have to inquire on that topic.
