Help! Power seats jammed all the way forward!
I have an '01 996 Turbo and today, I moved the power seat forward to replace the rear floormat. When I released the adjustment switch the seat continued to move forward. I heard the fuse pop when it reached the end of its travel and it would not move after that. I replaced the fuse and it blew again immediately when I tried to move the seat. Long story short, the seat bottom and back are all the way forward and I cannot get in the car at all. Furthermore, I cannot remove the seat as I can only access the two rear mounting bolts! HELP!!
+1 on checking for exposed wires...Usually there is a plastic cover in front of the bottom seat cushion. Pop that off and there should be a mechanism from which you can use a hex driver to manually crank the seat forward of backward. Good luck.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Thank Hurd.....I have removed the switches from the side of the seat. They are micro switches and are not serviceable. I can hear a clicking from under the seat as in a relay. Oddly, the switch activates the relay clicking whether the fuse is in or out? I have looked everywhere for a way to access a cable or gear to manually roll the seat back. I have looked for a release mechanism and cannot get the seat to budge in reverse. I did manage to get it to move more towards the front!!! I tired whacking the seat rail with a hammer while activating the switch in reverse. Now I have resorted to disassembling the seat completely!!!
Sincerely,
Macster.
It almost sounds like a wire got caught in the mechanism and created a short when the gears ran over it.
If that's the case, if you can find the offending wire, perhaps you can get two ends, jump it and get the seat moving again.
![Wink](https://rennlist.com/forums/images/icons/icon12.gif)
I had the exact thing happen to my seat. The wire that runs to the motor between the seat cushion and backrest wore through to the copper and is shorting against the metal holding the two seat pieces together. When you move the seat forward, the exposed wire came in contact with metal and shorted the fuse. Find that wire and you should be able to move it away from the metal part of the seat for proper removal and fix with electrical tape.
I have tried using the 3 preset buttons, but no love. Mirrors move, but not seat. Chsu...where specifically was the wire between the seat cushion and back? I am going to give this a look in the am. Thanks!
The tech said that replace the fuse, but do not try to move the seat forward or backward because of course the fuse will almost certainly blow again. Instead raise the seat as high as it will go.
Then unscrew the drive cable from the motor (he says there should be 2 motors and thus 2 drive cables).
Use a properly sized electric drill motor to move the seat forward then backward to gain access to the bolts.
Because there are 2 drive cables you'll have to alternate between the 2 moving the seat forward or backward in stages.
The tech did not say what to do if the fuse blows or the raise/lower motor of the seat doesn't work.
Sincerely,
Macster.
this is why i love manual seats!! nothing more frustrating that power seats not functioning.
