Correcting Off Center Steering - Tie Rod Adjustments
The steering wheel on my 996 is slightly off center, the wheel needs to be turned a little left to track dead straight, and I’m going to adjust the tie rods a bit to center the wheel.
My question is: does anyone have an idea as to how I can measure the turn of each tie rod adjustment screw so that I adjust them exactly the same(but in opposite directions) on each side? My first thought was to mark the wrench and then measure from the garage floor on each side, the starting point and ending point of the turn of the wrench. I do not want to change my alignment at all, so I need to make sure that each tie rod adjustment screw is turned the exact same amount.
TIA for any suggestions.
Watching for an answer myself since the place that did my alignment a few weeks ago also didn't center my wheel perfectly. Really annoys me to see the wheel turned slightly to the left when I'm going straight!
If you loosen the locking nut on the tie rod and then carefully turn the adjusting screw the same amount on both sides(in the appropriate opposite direction of course) you will not affect the alignment.
If you recently had the alignment done , I'd take it back and make them fix it. They should make it right IMHO. Good luck getting it fixed.
this...pulling with steering wheel will not work especially if you're just a little off. Mines moved a little off center...it seems like another alignment is due as my front toe seems a little off also....I'm gonna blame it on all the pot holes on 422 haha
I didn't bother with how much movement comes from a turn of the tie-rod end.
I measured from the front of the tire over to a spot under the car and noted the dimension. I repeated this measurement from the other front tire to the same point and then adjusted the tie rods to shorten the longer distance and lengthen the shorter distance.
If you do go this route -- and I do not recommend it -- sneak up on the final setting.
My advice would be to take the car to an alignment shop and have the job done right and always in the future specify the steering wheel be centered.
However, a shop that deserves your alignment business shouldn't have to be told this... centering the steering wheel and checking it remains centered during the alignment process is part of a proper Porsche alignment.
Sincerely,
Macster.
