Change hydraulic line between pedal and clutch
Does somebody know how to change the hydraulic line between the clutch and the pedal? This hydraulic line is fabricating in 3 parts, I want to change the central part of the line.
Thank you, best regards.
Because the central part of the line was cutted by the lift arm at the garage. I don't want to change the entire hydraulic line just the central part.
Thank you for your help.
It looks like you might need special tools to separate the middle line.
I think this is from a Turbo
From Renntech.org
Clutch slave cylinder and accumulator replacement.
Posted by jpflip on Aug 01 2008 09:43 PM
http://www.renntech.org/forums/tutor...r-replacement/
"9: Remove the forward line but first you have to unscrew it from the bottom where the line is green. 2 wrench of 15mm. Catch the extra fluid. This fluid is coming directly from the forward reservoir. And after remove the line completely from the slave cylinder.
10: After you have to use the fuel/ac removal tool. I purchase a set for $13.00. It is to hold the red collar in place when you want to pull the middle line out.
11: The last 2 bolts 15 mm hold the cylinder to the transmission.
12: you can now take out the cylinder."
From Renntech.org
