as wwest said ABS doesn't care about diameter. Those fronts are fat compared to the rears 245/265. I doubt you'll have to worry about understeer. I moved from 205/255 to 225/255 and it helped reduce understeer quite a bit.
I would say no problem,...but what is the goal...softer ride?
The goal is to reduce understeer and improve turn in for AX and track duty. Also on corner exit this should also help free up the rear end a bit.
Later next year I will be installing ROW M030 to help decrease body roll and help with overall car balance.
