Rough idle and CEL help needed
Well, just to finish this thread off, THE FREAKIN CAMSHAFT IS BROKEN! So goes the most dependable Pcar I have ever owned BS. This same right side we replaced the lifters on about 2 years ago and now the end of the camshaft falls out when trying to replace a lifter. Absolutely stupid.
What has probably happened is the VarioCam at the end of the intake camshaft has failed. The cam still turns it is just the VarioCam feature on that side that doesn't work.
Generally I consider the last thing touched suspect and I note the lifters on that side were replaced, but 2 years ago is a long time and anything done wrong at that time should have manifested itself before now.
Regardless, the problem is not fatal and can be addressed -- I believe (hope anyhow) -- with the engine in the car.
Sincerely,
Macster.
Broken camshaft not likely as the engine would not run because the valves on the side with the broken camshaft would be hit by the pistons.
Sincerely,
Macster.
Sincerely,
Macster.
It could have been an expansion plug on the end of a camshaft that blew out.
Dharn had a similar thing happen to him, after putting too much pressure on the expansion plug with the cam lock down tool.
Nope, the cam was probably carcked and then came apart at the journal between 4 and 5 once unbolted. Unbelievable, and it has been 4 years almost 30,000 miles since the lifters were replaced on that side. Funny thing as we went looking for a used right side intake cam and there are none around....probably a good reason for this as there are plenty of left side ones?
This wasn't the idle problem so we are replacing all 4 lifters on #6. Can't make the missfire move to another cyclinder. At this point I just want a rough idle again!
OK Final verdict was most likely a sticking exhaust lifter as we only replaced the intake lifters 4 years ago. Really lucky this happened before the cam finished breaking into two pieces and ruining the motor most likely. So, one new intake cam also. A lot of money to spend on this car but it had to be done.
Hope nobody needs this thread in the future?
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
