996 Forum 1999-2005
Rough idle and CEL help needed
Old 10-29-2011, 12:03 AM
Steven C.
Steven C.'s Avatar
Default Rough idle and CEL help needed
Well, kind of stumped on where to go next on this one. My 02 C2 will run fine all day and then for no reason I get an intermitent rough idle. Most of the time after a few seconds it will fix itself without touching the throttle? Other times it will not until you get going to the next light and idle again...and its fine. When hot and idling in park you can induce it by bliping the throttle and most times it will fix itself again after a few seconds.
It will pop a CEL every once in a while and always misfire #6. So, replaced all the coil packs since the car has 98K on it. No difference. Cleaned the throttle body and MAF, no change. Replaced just the #6 spark plug and made it worse! Have had the Porsche computer on it and nothing really stands out. What might look bad for a while then goes away while reading the engine at idle.
Ideas appreciated.
Old 10-29-2011, 12:34 AM
jrgordonsenior
jrgordonsenior's Avatar
Replace the MAF. Cleaning doesnt work IMHO.....
Old 10-29-2011, 12:38 AM
logray
logray's Avatar
Try swapping coil packs to see if stumble/misfire follows.
Check/clean/swap fuel injectors.
Test compression/leak down.
Post the exact DTCs you are getting.
logray
logray's Avatar
MAF at idle though?
Old 10-29-2011, 08:09 AM
Steven C.
Steven C.'s Avatar
Misfire does not travel with the coil pack. Leak down heads where I am thinking, lifter going flat? But a spark plug change making it worse makes no sense. That is why I am stuck on electrical?? I have heard that on the MAF, may be it but a lot of money to guess with.
Thanks guys!
Old 10-29-2011, 08:47 AM
ssukduang
ssukduang's Avatar
I had the same problem. The dealer tried everything common to a misfire (coil, plug, etc) and nothing worked. Had it in the shop four times.
Strange enough, for me it turned out to be the flywheel. It was either slightly imbalanced, installed improperly by under the care of the po, or came slightly lose.
The dealer replaced it under CPO and it finally resolved the mystery misfire.
Old 10-29-2011, 09:36 AM
Barn996
Barn996's Avatar
Good suggestion.Cleaning my MAF only lasted for a couple of weeks. New MAF has been good for 3 years plus.
Old 10-29-2011, 09:56 AM
jrgordonsenior
MAF at idle though?
Yep. Easy test, just unplug it and see.....
Old 10-29-2011, 10:59 AM
tarzancoe
tarzancoe's Avatar
Does it do it when cold? If not and only when hot, it might be a clogged purge valve that does not allow engine fumes to escape thus gas does not flow correctly. It throws no errors.
Or, gas lines?
Old 10-29-2011, 11:11 AM
nick49
nick49's Avatar
Misfire on #6 and changing plug made it worse, coil pack no diffefence. I'd change the plug to another new one on #6
What code does this throw? Are you clearing the cel? Does it continually throw a cel and code?
I'd look at an injector. I'd think at idle it could cause a lean mixture and misfire only on one cylinder. Is condensation in fuel tank possible? Is fuel tank low? Try some Heet to displace moisture.
Old 10-29-2011, 11:21 AM
Steven C.
Steven C.'s Avatar
All good ideas. Next is fuel injector cleaner and heet as I have heard these before. It does only do it hot, the cold start sequence works fine. Thanks for the ideas!
Old 10-29-2011, 04:46 PM
Macster
Macster's Avatar
Ideas appreciated.
The misfire error code is flagging a weak cylinder. If the misfire is not accompanied by a flashing CEL the misfire is due to a mechanical problem.
If you can with the Porsche computer you have disable the spark/injector fuel pulse to each cylinder in turn -- with the engine up to temp and idling -- and note the rpm drop.
Chances are high when you kill the #6 cylinder the rpms will drop less, indicating the #6 cylinder is not contributing as much to the engine's idle speed as the other cylinders.
The question then becomes 'why'?
What did the original #6 plug look like? I'd like to know what it looked like compared to the other plugs too. If it looks like it has been running 'hot' maybe an injector is weak and the misfires are due to a lean mixture.
If the plug is 'clean', this is a sign coolant is leaking into the combustion chamber. A head gasket failure, a crack in the head, or even a crack (D-chunk failure) is the likely cause.
A collapsed lifter should be considered, but this usually is accompanied by some noise, ticking. A flat lobe on the cam is another possibility.
If the engine has VarioCam Plus, the mechanism that provides the variable lift on at least one intake valve of one cylinder is suspect as well.
With the right Porsche computer you can activate the variable valve timing and lift feature per bank and probably eliminate or confirm there's a problem.
Sincerely,
Macster.
Old 10-29-2011, 05:10 PM
Steven C.
Steven C.'s Avatar
Thanks Macster Very helpful. The CEL never flashes so these are some good ideas. The plug was normal just the gaps were huge with 30,000 miles on it? No coolant loss and the car runs perfect off idle. Gas milage is down though about 1.7 mpg.
Old 10-29-2011, 05:11 PM
C4CRNA
C4CRNA's Avatar
Isn't #6 where the famous crack in the head usually appears?
Old 11-01-2011, 06:38 PM
Steven C.
Steven C.'s Avatar
Well, just to finish this thread off, THE FREAKIN CAMSHAFT IS BROKEN! So goes the most dependable Pcar I have ever owned BS. This same right side we replaced the lifters on about 2 years ago and now the end of the camshaft falls out when trying to replace a lifter. Absolutely stupid.
Quick Reply: Rough idle and CEL help needed
