FabSpeed X Flow 200c Cats
Ok, I installed the new FabSpeed XCats. Hesitation the same. Checked for leaks and found both clamps, from the OEM Cans to XCats, are leaking exhaust. Tried to over toque but still leaked. The FabSpeed XCats pipe is slightly smaller than the OEM Cans.
OEM Cats to Can:
6.75” circumference.
2.15 diameter.
FAB X Cats To Can:
6.625 circumference.
2.11 diameter.
Not sure if new clamps will stop leak, with the discrepancy in diameters. Anyone know the if newer model XCats pipe cats to cans has the same diameter as OEM Cats?
OEM Cats to Can:
2.15 diameter.
FAB X Cats To Can:
2.11 diameter.
FVD, no problems....
Guess I was wrong when I wrote Fabspeed will schime in....? An explanation from the manufacturer would be helpful to those customers new and old? Hello??? Fabspeed....anyone home?
I Ordered new clamping sleeve and installed the FABSpeed CATs. Will
install new clamp sleeve when they come in. Reset the computer and
torqued all bolts. Running great except for low end lag.
Basic Sponsor
Hey Guys, sorry for the delayed response. This issue is very strange and we have not seen it before. I checked with many of my customers and they are not experiencing this problem at all. We have a bone stock 997 in the shop and we are going to see if the same problem occurs. The 996 and 997 use the same X Pipe Sport cat on both cars. If there's no leaks on the system or issues with the Cats, there shouldn't be anything wrong, especially if you aren't getting any kind of CE light. We use only the Highest quality HJS Sport Cats which are guaranteed not to cause any problems and the X pipe allows the exhaust gases to talk and improve flow balance.
This is a very unusual problem but we will try to track it down and find a solution for it right away. Thanks for being patient with us and I will be back with updates and answers when I have them.
Thanks,
Thanks,
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
I just installed a gently used x-pipe (cat delete) this weekend. Pretty simple install. I have only got to drive once but WOW! Even my wife noticed the difference in power around 3,500rpms! Feels like a good 20hp.
I got zero hesitation on any type of load. It does have a little hesitation revving the engine when its cold.
So far I am loving the sound and power! I have stock headers and a set of used cargraphics mufflers.
If we get slow at the shop I will put it on the dyno and see where it is. I don't have a base line...
Put new clamps on this weekend and still have the hesitation/lag
problem. There is a small leek with the clamp on the FABSpeed cat but
haven't driven much. We'll see if the leak seals up as I drive the
911 this week. Everything is running great otherwise.
