Hello, pretty much all the time except when its quite cold out I get cel light, when cold outside it goes out in fraction of a second so thinking its evap. i pulled codes here is what i have p0446 system vent, p1126 p1124 no data on last two. 1999 996 911 carrera cabrio. all help is greatly appreciated. thanks Rod
My info is the P0446 is a leaking canister purge line. The test is to disconnect the line and blow compressed air through it to test for leaks. Don't go crazy with the air pressure.
For P1124/P1126 the air/fuel mixture is so lean the DME is at its enrichment limit.
Possible causes are intake system leaking (which could be an AOS leaking); fuel pressure too low; fuel injectors contaminated; fuel supply low or fuel not getting to the fuel pump.
Of the above, fuel supply/pressure problems are generally rare, while almost every owner (it seems) has had an AOS go bad, so I'd suspect the AOS first.
