996 Forum 1999-2005
Constant noise in driver's door on a cab
Old 10-13-2011 | 03:57 PM
BlackBear's Avatar
BlackBear
Default Constant noise in driver's door on a cab
Hi,
I bought a 2004 Turbo cab with 15,500 miles.
Great car, but it has a noise that drives me crazy. I only drive the car with the top down.
There is a noise coming out of the driver's side door. It is so loud that my passenger can hear it. Window up or down only makes a tiny difference.
It sounds like some part inside the door has tension and constantly vibrates. The vibration is amplified since the door acts pretty much like the body of guitar.
I'll take the door panel off this weekend to see what it is.
Do you guys have any ideas what I should look for? Should I use Dynomat for the inside of the door?
Thank you.
Old 10-13-2011 | 05:36 PM
tbanasiak's Avatar
tbanasiak
Money?
Old 10-13-2011 | 05:43 PM
Pac996's Avatar
Pac996
Only thing you can change for trouble shooting that I can think of is have the door locked while driving to see if the noise changes any so that it might give away that it's part of the locking mechanism.
Old 10-13-2011 | 05:51 PM
BlackBear's Avatar
BlackBear
Thank you both.
It is not loose change.
I'll try locked and unlocked to compare.
I just looked at the parts diagram for the window regulator. That could be the culprit.
Old 10-13-2011 | 06:02 PM
wyovino's Avatar
wyovino
One more thing to check - where the top grabs onto the windshield above the sun visors (not the center point). I had a creaking noise from the one on my passenger side because the two screws were loose. They're hidden behind a small removable piece of plastic. This probably isn't your problem, but it couldn't hurt to check.
Old 10-13-2011 | 10:35 PM
Rrrockhound's Avatar
Rrrockhound
Originally Posted by BlackBear
Hi,
Thank you.
I had this too. Try greasing the metal striker loop in the door jamb. The noise went away immediately, hasn't been back.
Old 10-14-2011 | 12:03 AM
EastBay's Avatar
EastBay
this is the rattle I had in the passenger door, speaker screw was backed out and this is what it looked like
Old 10-14-2011 | 12:17 AM
Hardback's Avatar
Hardback
I have the same noise. Let us know if you figure out the issue. I only hear it over sharp bumps.
Old 10-14-2011 | 12:46 AM
sheatley's Avatar
sheatley
ditto on above for passenger door. It is now on my driver door, have not had time to pull off the panels.
Old 10-14-2011 | 12:48 AM
BlackBear's Avatar
BlackBear
Thank for all the ideas and areas to check.
