FS? 1999 996 intermix just showed up here
This is from a local board called C&C in NJ
"Well, when I say I used it as a daily driver, I mean it. My 1999 911 has 178,000 miles on it. For the most part it's been very reliable except for a little nagging issue of spontaneous engine combustion.
The first engine died with 95000 miles. Something about ring wear (Porsche doesn't really tell you what's wrong). That was replaced under warrantee, so it wasn't a hit to my pocketbook. Now, the second engine bit the dust with about 85000 miles on it. "Intermix" is the problem. I.e. oil in the coolant indicating a crack somewhere, probably the heads. Porsche's answer: replace the engine. They answer this so fast to so many problems, it's a bit crazy. The dealer said they don't even need to look at the car. I described the intermix problem over the phone, and the guy said I need a new engine. Case closed.
With a car worth $10k to $12k on a good day with all the stars aligned, and $8k plus to install a new engine, the math just doesn't add up. The car's worth more in parts. So to a breaker it will go.
Unless there's someone out there just itching for a dead 911 ... ;-)
Ross"
candcnj@yahoogroups.com; on behalf of; Ross Fox [rossjfox@hotmail.com]
Ross"
Anew engine (remanufactured) at the dealer is going to be closer to $20,000 than $8,000. Here is a chance for someone who wants a dead car or wants to rebuild the engine.
Parts Specialist
He just listed it on ebay and he's a member over on RT.org...
http://cgi.ebay.com/ebaymotors/1999-...-/140611098893
http://www.renntech.org/forums/topic...08#entry209508
If it wasn't such high miles I would consider snapping it up and fixing it. But I wouldn't be looking at a huge profit, maybe 1-2k after repairs and flipping it.
Edit: holy crap $10k blue book for a car with good engine and that many miles. Wow.
Ok, staaaaay away. Unless you need a donor car or want to part it out.
Parts Specialist
trouble with intermix is it could be head replacement (less expensive) or block replacement (more expensive)
Real...what's real... I live in a land of make believe. to me all you guys are real..... who knows
