FS? 1999 996 intermix just showed up here
#34
#37
Make sure that both fans work on high and low speed, Ballast resister may be out?
Did you ever change the water pump? The intermix might have caused some deterioration of the plastic impellers. Impeller breakup is not uncommon.
#38
1 Post
That's exactly how mine acts. That makes me feel a lot safer lol. I've been very nervous about it heating up to much after all that I have research I have done on the car. It hasn't passed the 0 yet. I replaced about everything on this engine and car itself so I know with out a worry about it. I have just read that people seem to see it stay right at the 180 mark. I do feel that the resistors need replaced bc when I kick the a/c on the high speeds come on but the low speeds or high speeds will come on without the a/c on. Also the engine compartment fan will not kick on either. I just put all new relays in also.
#39
^^ my car acts exactly the same as franks and yours. Totally normal. The engine compartment fan does not kick on very often. IIRC the engine compartment itself has to reach 176F or the coolant temp needs to reach 216F for the engine compartment fan to kick on.
