The Check Engine Light
Just came on in my 996. 155k miles and just had emissions checked and passed. Last oil change at 150k and good oil level. I have good oil pressure and temp. and appropriate volts. Engine sounds fine and runs fine.
Any ideas?
Thanks in advance...
JKC
Any ideas?
JKC
And.......check to make sure the oil fill and gas caps are tight. When I first had my car I checked the oil. The car threw a CEL in 2 days and I took it to the dealer. It was a loose oil fill cap. Learned a lesson that day.
With a code we'll be able to tell you why the CEL was thrown. Code readers are relatively chep unless you get the actual Porsche reader that also will erase/reset airbag codes.GL
In Your Face, Ace
It happens when people 'top off' their fuel when filling up. When the nozzle clicks off, stop because it's full enough. I imagine spirited driving with a full tank can do the same.
