Impact Screwdriver on Rotor. Bad for bearing?
I used an impact screwdriver on my brake rotor screws when doing a brake job recently, and it got me thinking...
It was a big help for a few stuck rotor screws. However, while whacking the stuck screws, it occurred to me that it might not be a great idea to impact the wheel bearings.
Of course, I did it anyway ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
My thought is that the hammer blows will be transmitted directly to the wheel bearing (thru the rotor and hub).
I worked with industrial bearings in a previous life, and hammers and bearings don't usually mix. Sharp impacts transmitted to the bearing can dent bearing races and lead to premature bearing failure. Not sure if this applies here.
What type of bearing is in these wheels?
Any opinions on whacking your rotors with a hammer?
P.S. I posted this question in Van's DIY changing brake thread, but I decided to start a new thread instead, just because I'm curious about opinions on this. Still a great DIY!![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Also, I like the idea of postulating on a possible bearing failure in a 996.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
My take on it is .... whatever gets it off is alright to me (this includes jumping on a 10ft breaker bar with a extension) however when re-installing care should be taken using the proper Tool/Torque
Given a large hammer, I'd bet that you could not damage the bearing no matter how hard you tried. Even with successive hard impacts directly to the hub, I think the bearings would do fine. Even hard impacts that will destroy a wheel and suspension components, more often than not will not affect the wheel bearings or hub. They are really tough in that regard.
However, with direct metal-to-metal contact (through the metal screwdriver) it's a different story. Here's a failure analysis for an industrial bearing that was hit with a hammer:
Also, the wiki for ball bearing installation states "For small bearings ... tapping with a hammer damages both bearing and shaft..."
Many bearing installation guides recommend using a block of wood, rubber hammer, soft brass punch, plastic dead-blow hammer, or an arbor press to avoid sharp impacts to the bearing races.
I still think it's plausible that hammer blows could shorten bearing life.
Former Vendor
As a fellow Design Engineer... You might be over thinking this one.... Keep in mind that the impact from the small screw being transmitted thru the HUB shaft that is in radial contact with the inner bearing race. Thus the impact load would not be true Point of contact (during many installation guides you are directed to ONLY apply force to the outer race) on the inner race. If you run a FEA simulation on the force transmission you will find the distance and mass of the Cast Iron Hub absorbs the Low impact force applied from the Hammer and Impact driver (which is designed to apply a light/Moderate downward force and a HIGH twisting (radial) force).
So, go ahead and use that impact driver... Just don't go get an Air impact Gun! That is a whole different Game...
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
