Replacing a stock 996 stereo
A couple months ago I replaced the stereo in my '83 944 with a new Pioneer DEH-3300 UB stereo (which has a USB port to plug in my iPod). I've since decided to sell the 944 but want to see if I can put the aforementioned stereo in my '04 996 (replacing the 996 stock stereo).
The 996 stock stereo has several cd drawers underneath it, not too concerned if they continue to work since they're obsolete and taking up space anyway so I'd just assume take out the CD drawers as long as there isn't a gaping open hole there (if it was a sealed off hole that I could use for storage, that would be ok).
So the question is, are these stereos interchangeable? Is anyone able to provide some steps on how to do this or must I pay $150 to the pros to do this?
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Also, if/when you order a cubby, make sure to order the top one. You'll be given the option for a top or bottom. Eagle Day and Pelican Parts both have in stock and you can also find on eBay occasionally.
+1 on cd storage unit replacement. Suncoast is another source for the replacement cubby.
As for the head unit...the '04 996 uses the MOST (fiber optic) bus system, not standard wires. It's a bit more difficult/expensive than straight plug-and-play. Do some searches here and other Porsche sites to research what you need; lots of folks have done what you're planning to do. FWIW, many posters discussing headunit replacements on '03+ cars seem to use professional installers, and the MOST system makes the cost higher than the typical "simple" install.
Good luck.
Good luck.
When I swapped the head unit out in the 996, I elected to use a professional installer. Your situation may be different, but my level of retardation in this automotive electronic sense would make Charlie from Flowers for Algernon look like Nicola Tesla. So, I coughed up the cash and summoned professional help.
Also, I swapped my CD caddy for a storage bin, and then sold the stock head unit and CD caddy for enough money to fund the new head unit and installation fees.
on either end, will I have to enter a four digit passcode when the new (different) stereo is installed in the other car? If so, how do I find out what the passcode is?
1k apologies, the picture of my CDR23 stock 996 stereo that I got from google images wasn't right. i replaced that pic in my original post with one that I took of my actual stereo via my camera phone.
If that stereo won't work in a 944 then the point is moot and I won't switch
Super Moderator
My level of retardation in this automotive electronic sense would make Charlie from Flowers for Algernon look like Nicola Tesla
It is true, though. As the book quotes, we shall not poke fun at others, simply because they drive a Gremlin or other oddly designed car:
"Any one who has common sense will remember that the bewilderments of the eye are of two kinds, and arise from two causes, either from coming out of the light or from going into the light, which is true of the mind's eye, quite as much as of the bodily eye."
