996 buyers are a different sort
#31
J beede, where are you getting the info that 99-2001 Carrera's that have had engine replacements have a 22mm IMS that cannot benefit from the L&N upgrade??? I HIGHLY doubt they redesigned the 3.4 just for replacement motors, that would have required a complete retool and new block design to my knowledge. From what I know, all 3.4 engines have an IMS that can be removed and replaced by the L&N bearing kit. Please share with us where it is stated otherwise?
David
David
#32
Much missed
#33
I love the fact that the OP thinks we're in denial. Why? Just because we bought one? The first page of the 996 forum always has at least one, if not several, posts on IMS failures and questions. There's even an IMS/RMS sticky at the top.
It seems like he should be criticizing anyone who bought a 996 (or ANY car for that matter) without doing some research on it beforehand. There's certainly a plethora of information about the M-96 and the 996 in general on Rennlist, Renntech and a dozen or so other websites. Maybe someone else who needs to be educated is the OP?
-Eric
-Eric
#34
The used 996 owners I have met have all (100%) confessed to buying their car on a whim, or without doing adequate investigation. They viewed the 996 as a $20,000 "toy" that looked cool. None (0%) of the 996 owners I know knew whether they had an original or reman engine before they were given instructions on how to find and read the engine code. None of the 996 owners I have met knew that the reman engine likely precluded the LN Eng IMSB retrofit. None of the 996 owners I have met knew that a single sealed bearing failure could end up costing them over $20,000 in parts, labor and "other" sensible repairs done at the same time. This is a different sort of a car buyer--in my mind this is how people end up in Smart cars and Nissan Leafs--not in Teutonic wizardry.
Actually I did not buy mine on a whim and I obviously paid much more than $20k for it four years ago. I'll admit that other than googling "2004 Porsche" and paying for a full car fax, I did not anguish for months in research. I knew about the RMS, was somewhat concerned until I read about the progressive updates to the replacements and mine was replaced when qualifying for CPO. I will add that I am still on that RMS and it was dry when my transmission was replaced about 2 years ago, under CPO. They replaced the IMS at the same time, "while they were in there". The single requirement that I had was that I purchase a CPO car. The IMSB catastrophy must not have been so well known, or published, or fed upon, in August of 2007 because my internet searches never showed anything, maybe I didn't research enough, who knows.
I do know that after spending some time here and on Renn Tech, I learned about it and I did stress in a major way. I pestered the hell out of the service manager. He insisted that although they knew about the issue, they had never actually had any in their shop. LOL - he finally got pissed at me and said "look - you paid good money for a CPO car - go out and drive it like you want to blow it up and if it blows up you'll get a crate motor installed for free". So - I pretty much followed his advice and darn, I should have known, the motor has not yet blown up (fingers crossed) and the CPO has long since expired. I put 11k miles per year on the 996 alone.
So - I don't think all 996 owners are of the breed you describe, but then again, not all 996's blow up as soon as the new owner drives away. As soon as I can find my "lucky" meter I am heading to the casino - have to find a way to get that GTS so I can put all of this IMS stuff behind me.
P.S. - if I had it to do over again and knew about the IMS prior to purchase - I honestly believe I would have purschased the car anyway. There isn't much I've enjoyed in my life that hasn't come with known risk.
Let's all drive and enjoy.
#35
Hummmm... - I was after an air-cooled, got caught up in the chase, blu-***** aching, $15,000 996 with the re-man engine and bit on it, no PPI. Am I a f*ckin idiot, ask my wife & friends.
Do I flat love this car and will work through any issue that arises? Absolutely.
If you are foolish enough to buy one of these cars for ANY reason other than you want one and nothing else will do, you deserve what you get...
If the motor takes a dump tomorrow, I will place a call to Cleveland, GA and weigh my options, if this sort of thing bothered me, I would enjoy driving my wife's Prius.
#37
They viewed the 996 as a $20,000 "toy" that looked cool. None (0%) of the 996 owners I know knew whether they had an original or reman engine <snip> None of the 996 owners I have met knew that the reman engine likely precluded the LN Eng IMSB retrofit. None of the 996 owners I have met knew that a single sealed bearing failure could end up costing them over $20,000 in parts, labor and "other" sensible repairs done at the same time. This is a different sort of a car buyer--in my mind this is how people end up in Smart cars and Nissan Leafs--not in Teutonic wizardry.
Yes my used 996 Cab with the hardtop was priced right for me and it does look cool and it's my toy car when I decided the 928 just didn't fit my liking even though that was the car I started lookin as the toy car. This 996 cab needed tires, it needed a good polishing, it didn't come with the owner's manual(!) and at some point in the near future I will have the LN IMS bearing installed and likely getting the AOS and clutch done at the same time, and oh yes I did know of the IMS, RMS, cylinder crack issues, and Rinnlist.com before I committed in buying this particular car, while I have been wreching my own cars for the last almost 30 years, I knew I didn't know enough about Porsche cars or the 996 specifically, so a thorough PPI was performed by the top independent shop in the area with lots of recommendations, including from my dentist!
BTW, who really "needs" a Porsche 911/996/997 etc.? These cars are not necessary to go to work or grocery shopping with, whoever buying these cars do so because it is unique, rare, status symbol, fun, enjoyable, so why do all the "used 996 owners" get stereotyped as clueless exotic car owner wanna-be?
#38
David
David
#39
My wife bought me my 996 as a total surprise. I immediately set out to find out exactly what I had. Fortunately for me I grew up dreaming about 911's and learned how to throw my 65' Mgb around corners, learned how to double clutch and heal toe. My first drive in my 996 one year ago was my first drive in a 911! Exactly everything I'd ever imagined and maybe a bit more! An hour after my first few trips taking my family each for a spin I dove into the Internet and learned to refer to my particular 911 as a 996 funny all those years of dreaming of a 911 and I never refer to it as one... It's a 996. Anyhow, I quickly had a bit of a sick feeling when I learned about the IMS, felt a little better at least mine was a 2001 and had benifited from some minor up grades from the 99 and 00'.
Here's how being overly aware of the IMS was almost as bad as actually having an IMS failure. Of course I needed a poor oil change a nice hot day and an unscrupulous and or stupid Porsche dealer to take advantage of the situation. I would have been a statistic of the statistics had I taken the $9,000 offer on the badly smoking car I had towed to the dealer. This forum and some common sense saved me from this fate. Many said check your AOS or maybe an oil overfill. Funny, with out the knowledge of the forum I'd have never thought my entire engine had blown up as I'd be blissfully unaware of the dreaded IMS failure. Then, lucky for me the collective knowledge of this forum guided me to retrieve my car from the dealer and determine what was ultimately the problem... Oil over fill.
Fortunately the car is so much fun to drive that even the nigling worry about the engine possibility blowing doesn't rob me of the pleasure.
#40
OP, could you please enlighten us on just exactly how many of these "used 996 owners" have you met? 3? 5? 10? 50? 100? I just can't envision that you have met enough of them to be statistically representative to support the statement strongly suggesting none of the used 996 owners knew what they are getting themselves into.
#42
Six. Not a statistically significant sample size. Clearly, none of them knew what they were getting into. They were "clueless" to use your term. Even within this thread you see 996 owners who are yet confused about IMSB--this in spite of the usual complaints that this topic has been beaten to death.
Most, if not all people buy a modern car expecting not much will go wrong if they just followed the mfg suggested maintenance schedule, especially for critical items such as timing belt on interference engines, but to the best of my knowledge the IMS bearing has not been identified by Porsche as one of those items under the normal maintenance schedule. I also understand there are 5 chains internal to the engine to drive the IMS and valve trains that need to be replaced at some point in time, but hopefuly not for a very long time unless engines are reported blown with timing chains issues!
It seems Porsche is just keeping quiet and replacing the IMS induced blown engines under warranty rather than coming up with a proper solution and offering a recall and extending the warranty.
Honda was in a similar situation with the auotmatic transmission of their V6 engines in the early 2000 to mid 2000s, it was under-designed where one of the gear set would overheat and break making a total mess of the transmission. Honda tried very hard to just pay to repair/replace the dead transmissions and not offering any recall or post warranty good-will repairs, eventually enough people documented the occurances and complained an US government agency (FTC IIRC) stepped in, telling Honda either to make this right for the owners or "we'll see you in court", Honda backed down, came up with an oil jet retrofit kit, and extended the warranty to (IIRC) 10 years and much higher mileage limit.
Doesn't look like Porsche will be doing that any time soon though ..........
#43
...on a whim? Sure.
I bought my first p-car, an '80 911SC, on a whim...great car. I bought my first and second 993s on a whim, too; both were great cars. I bought my '99 996 cabrio w/hdtp on a whim, too; another great car.
After 25 years of 911 ownership, I don't have a problem with those who buy on a whim. There's room in the tent for everybody.
Finally, after meeting P-car owners of all vintages, cars and owners (!), over the years, I have not discerned any major differences across groups in re. technical knowledge, brand enthusiasm, or whatever.
relinuca
relinuca
#44
FYI, I had an IMS failure on my 1999 996 so I know how painful it can be. Did the L&N IMS upgrade on both my 2000 Boxster (original single row bearing was in bad shape!) and on my current 2001 996 (dual row bearing looked to be perfect go figure) so I am a happy customer of this solution.
#45
So I understand... even though it is a 3.4 motor with a case designed for the older style IMS bearing they retooled the cases on newer 3.4 replacement motors to use the newer bearing?
I did not think Porsche would find it cost effective to retool the older 3.4 case design like that...
Porsche does not like having multiple components in use at once, when the new bearing was developed a global change occurred between all engines, new, and reman..
Once again, no re-tooling.. They simply threw the newer IMS in at assembly time, its a seamless integration.. Hell, we can remove the new style IMS and bearing and back date it to as eary as a 2001 arrangement, or can use a 2008 bearing in a 2001, they share the same IMS drive on the crankshaft.
Porsche would have had to continue making the old style arrangement to keep the 06 and newer 3.4 engines using it. The 997 or these bearings are not special.
In closing, if you have a new or reman engine made post 2006 it has the 997 style bearing, NO MATTER what displacement or application it fills.
