I have been thinking of doing the LED taillights on my car for a while, but it is amazing the price variation you see on these, particularly when they all seem to come from the same manufacturer. A couple of years ago Amazon had them for $214, but not for long, and now you see them for $500+ on the high end. Here is a source for $339 shipped, which is the lowest I have found in quite some time.
Just got them today. Install was pretty easy, but for some reason the fuses for the side marker lights kept blowing. They were 7.5 amp and I switched them to 20 amp and now they are working. Any ideas? Do I need a resister? These are supposed to be "plug and play."
I would NOT put a larger fuse in there. I have read about the fuse problem with the side markers, but have not seen a solution. Using a larger fuse opens you up to potentially costly problems. I would disconnect the side markers until this is sorted out. LED's should use less current, not more. Maybe someone with an electronic background will chime in here.
If you put a 20 amp fuse in the place of a 7.5 amp fuse you are asking for a wire fire. Promptly take the 20amp out and find out the solution first.
Trust me you don't want to have a wire fire!!
