Replacement battery questions
2 questions...
1) do I need to use an external power unit to prevent the radio/nav from locking me out and thus requiring the radio code etc...
2) any recommendations on batteries? Dry cell e.g..?
Thanks....
I would find a battery with a good warranty from a store/dealer that has a lot of locations.
My old 40th took a group size 48. My store will tell you it is a group size 49. That is wrong. That battery is to long. Make sure the battery you buy have the vent tube connection.
https://rennlist.com/forums/996-foru...t-battery.html
"I just replaced a good Interstate MTP-H7 With a Braille 7548 AGM battery direct replacement.
Braille AGM B7548 battery group 48
BCI Group: [?]Group 48
Length:10.9" (277mm)
Width:6.8" (173mm)
Height (without posts):7.5" (191mm)
http://www.braillebattery.com/index....tteries/b7548#
Interstate sizes that fit 2003 996
Group
Size Interstate Type CCA1 CA/
MCA2 RC3
(Min.) Warranty
(Months) Dimensions (inches)
L x W x H Posts
H6 (48) MTP-H6 640 800 121 85 10-15/16 x 6-7/8 x 7-1/5 Top
H7 (94R) MTP-H7 640 800 135 85 12-3/8 x 6-7/8 x 7-1/5 Top
H8 (49) MTP-H8 720 900 176 85 13-15/16 x 6-7/8 x 7-1/5 Top"
http://www.renntech.org/forums/topic/2950-battery
Lost radio code thread:
http://www.renntech.org/forums/topic...r-request-here
