Cooling fan mod or Lower T stat which one
For lowering the temperature in stop and go traffic the fan mod is probably the most helpful.
For minimizing hot spots in the engine and getting fluid flowing through the system earlier, the low temperature thermostat is more helpful.
I've got the third radiator and lower temp thermostat and when cruising on the highway or at the track my temps are pretty low. When I'm in stop and go traffic things still get plenty hot. That's where fans help.
-Shawn
-Shawn
If you haven't cleaned out the space between the rads and the condensers do that first! You would be shocked by the crap that will find its way between and slow down air flow.
Rocky Mountain High
My temp was doing this too in traffic and in hot weather, and I ended up having both of my fans and relays replaced. Since the replacement, my temperature stays right between the 8 and the 0, no matter what the conditions. I think I may have had one fan out for some time and it was barely holding on, and then the other went out which is when I really noticed the problem.
LOL. Another "oil" thread I can see it already.
The fans are going to come on whether you want them to or not. The question is, are you going to be a worrywort and turn them on before they are going to anyways? And why do you think Porsche picked the temps to turn the fans on automatically anyways (stage 1 206F and stage 2 215F)? Why wouldn't have they picked 180 and 190? Probably SMOG. But do you think they would have picked 205 and 215 if they thought it was dangerous for the engine?
I've driven through 115+ degree temps before uphill at 100mph and the stock cooling system adequately prevented the temp from going past the 0 in 180.
Obviously I'm on the other side of the fence. I say don't mess with it, if the car runs 10-20 F degrees hotter sure I might be loosing 5 HP but at least I'm doing something for the environment.
The best thing you can do, IMHO is add a third radiator to the setup. The only fan mod I might consider is the engine compartment fan hack to help in stop and go or idling on a hot day. I agree with Doug - Even with a thermostat that opens sooner or fans that click on sooner (or all the time) the car can still get hot, depending on how it is driven or the conditions.
I wonder if any of the people who have done the fan mods have had more fan related problems sooner than those who have just left it stock.
I've seen no impact on fuel economy or performance.
Good thread
https://rennlist.com/forums/996-foru...erheating.html
Don't know if it is correct but "190F - 200F" = "87C - 93C"
https://rennlist.com/forums/4292128-post17.html
I believe everything Dharn55 wrote in his last post is true, also according to Autofarm in the UK since coolant enters the case on 1 side & flows to the opposite side all the while being heated by each cylinder, the low temp thermostat's earlier opening helps to minimize excessive heat @ the far side cylinders for those of you who hit the high rpm's before full warmup.
Wow thanks for the advice are the fan temps controled by the computer ie: on at X temp and off at XX. If so can they be adjusted with a Teck 2 or HP tuner type of program. Its an 04 and has 29K miles on her. My rads are clean fans both work but my temps were above the 0 on the 180 mark. What I noticed mostly was the feel of the car, slight drop of oil pressure power seemed slightly down, not as responsive. Like it was melting a bit. Heat soak if you will. Maybe I just need to get use to how it feels. My vett performs the great even on 100+ degree days although she does feel like its melting too.
