Slightly wider 18" tires
Has anyone successfully fitted 235-40/18 and 275-35/18 tires on the standard 2000 18" rims?
The reason I ask is the specific model tires I'm looking at are new and not yet available at the 265-35/18 size but 275-25/18 is listed, so I thought to go up 10mm both front and back at the same time to get a bit more contact surface area.
TIA.
TIA.
TIA.
TIA.
I have 265-35/18 on the rear 18 x 10" but many recommend wider, 285 even 295. I will definitely go wider (285) in the rears when the time comes.
Former Vendor
It isn't a problem fit. 235 fits all but the most slammed cars. 275 is a good fit too. If you have an 11" back rim, a 275 minimum will be needed. Watch your OD's if AWD.
Please call me if I can help.
