Coolant Temp Acting Weird!
Cheers
Cheers
Why are you trying so hard to lower the temperature? If it's not even in the range that the factory thought required the fans to be on "high", it's unlikely to be an issue. There is a range of optimum efficiency for engines when it comes to temperature. Too cold isn't desirable either...
-Shawn
-Shawn
-Shawn
-Shawn
Cheers
Did the change correlate with the change in ambient temperatures? I live in Boston, MA (not exactly a hot area) and when driving in the city my temperatures are typically in the same range. When I'm on the highway they drop into the 80's.
Does a boxter run cooler as compared to 996s? I have got a friend who's boxter runs at 87C max.
Cheers
1 Post
Mine is doing the same as yours all of a sudden this Summer. Cleaning my radiators helped a bit but it's still higher than previous years. The other obvious difference between the years is that it's been extremely hot since June here and I've noticed many people posting on sites about their temperature readings so I'm just going to chalk it up to climate change and sun flares.
