Another Successful Radiator Cleaning
After reading a few treads, I decided I too should clean my radiators. Wow, there was so much junk in there. I wish I took pictures because I think my car could have been the poster child of why they should be cleaned. Anyway, my temperature needle would get past the "0" in the "180" which I would estimate to be about 205 F. Since the cleaning we have had a heat wave with temperatures in the upper 90s and yesterday it hit 100 F. Even with the insane ambient temperatures, my needle pretty much stays vertical making it about 185-190F.
Mileage,tips,how to?
It makes you feel good after seeing the amount of crud that collects in the condensers and radiators. I just felt that my Porsche was cooler and much happier after doing the same.
Good to hear. On Monday I'm pulling the bumper and doing this for the first time since I've owned the car -- and I suspect in the first time since the car rolled off the line. My temperature is ever-so slightly past the 0 in 180. I will take some pics.
My car runs at 183 degrees at 95 outside and when it is 76 and raining exact same temp 183. Does it need cleaned?
I would think the thermostat keeps the engine temperature fairly level to a point but your rads will be more efficient if they're clean. I had no temperature issues but look what I cleaned out of mine:
The rads in the front of the 996 really are just vaccums for road debris.
here is mine mess from last year:
Just finished,about how mine looked. Doing new horns also.
Everyone, please keep in mind if you don't clean between the radiator and A/C condenser, you really have not removed the main area of debris accumulation and blockage.
![](http://www.gjlenterprise.com/radiator/4.jpg)
