X-74 suspension question
I just had the X-74 suspension kit installed in my 2003 C2. I now can only get -30 min. of camber maxed out in the front. I did not expect alot w/o camber plates or control arms but this does not seem right as usually lowering will net you more. It makes me wonder if the install was done correctly as I think you can get more even with the stock suspension. Thoughts?
I have the same setup. The x74 c2 alighment calls for -30 min +/- 15 min front camber. So if you meant -30 min, your alignement is right on. My impression is you don't get much more cambers even with x74.
