996 Forum 1999-2005
key / ignition issue
Old May 4, 2011 | 07:07 PM
copper's Avatar
copper
Default key / ignition issue
I have been having some problems while trying to take the key out of the ignition. It has been hard to remove the key. Yesterday I removed the key and the dash said that the key was still in the ignition. Put the key back in the ignition and then took the key out and all was ok. I tried to put silicone on the key but that did not help.
Am I guessing right that I need to replace the Ignition Switch as seen here Ignition Switch replace (just the switch)
with part from NAPA
Ignition Switch
Part Number: ATM 4A0905849B
https://www.napaonline.com/Catalog/R...&Dk=1&Dp=3&N=0
What do you guys say?
Old May 4, 2011 | 08:22 PM
fpb111's Avatar
fpb111
yes
Old May 4, 2011 | 09:28 PM
Barn996's Avatar
Barn996
I would also concour.
Old May 4, 2011 | 09:54 PM
redridge's Avatar
redridge
seems to be the standard fix.... and its cheap/easy diy.
Old May 4, 2011 | 10:06 PM
Marc Gelefsky's Avatar
Marc Gelefsky
Super Moderator
Indeed, Replacing it was no fun...
Old May 5, 2011 | 11:51 AM
Hardback's Avatar
Hardback
Do it yourself but be prepared to contort yourself in the footwell. I think dealers charge upwards of $400 while the part is only $12. Your gonna need a torx set in order to take the ac vent out. Also pickup a headband flashlight as holding a torch with your teeth is no fun. Process takes about 20-30 minutes first time. Carefull with the leather dash...
Old May 5, 2011 | 01:55 PM
Tom M's Avatar
Tom M
Originally Posted by Hardback
Also pickup a headband flashlight as holding a torch with your teeth is no fun..
+1
The headband light is the only way to go when working on your back at the odd angles required for this. It also makes swearing a lot easier when things don't go smoothly
Old May 5, 2011 | 07:30 PM
copper's Avatar
copper
Originally Posted by Tom M
+1
I am pretty good at the swearing part. I guess I really need the light. Thanks for the heads up.
I had to move the car again and again it said that the key was still there. I found if I turn the key a little hard to the left (Counter clockwise) the key comes out easy and I don't get the message.
Do you guys still think it is the electric Switch?
Sorry to ask again. Just want to make sure before I crawl my 6'4 250 lb *** under the dash.
7 Porsche Models That Have Aged Like Fine Wine
Old May 5, 2011 | 08:00 PM
redridge's Avatar
redridge
might need to remove the front seat.
Old May 5, 2011 | 09:47 PM
mglobe's Avatar
mglobe
The Penguin King
Difficult to say for sure, but I'd try replacing the switch first. That's a LOT easier than replacing the entire ignition switch assembly.
Good to meet you last weekend BTW.
Old May 26, 2011 | 08:32 PM
copper's Avatar
copper
Well the switch finally died. I got into her today after work and the key was hard to turn. She started and then NO ac. I knew right away that the part died. Luckily, I had purchased one waiting for this day. Got home and started to take her apart. I did not have a torx screwdriver that would fit into the hole behind the light switch, so off to auto zone I go. Get home and finish taking her apart. Got to the switch and I could not fit under the dash to work on the two set screws. Grrrr. So here come my HERO! The wife crawls under the dash and get the screw out enough to pull out the electrical part. she then puts the whole thing together but the first three screws and the light switch. What a trooper.
It was nice meeting you too mike. Hopefully I will get to see you TWS in June.
Old May 26, 2011 | 10:11 PM
Hardback's Avatar
Hardback
Your wife replaced the switch? That's is so cool. Ferdinand you called it bro.
Old May 26, 2011 | 10:52 PM
SSST's Avatar
SSST
LOL! Glad it got fixed. Mrs. SSST has been known to get her small hands in places where mine don't fit.
Old May 26, 2011 | 10:56 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Isn't it nice to have an apprentice sometimes to fill in! Nice job!
Old May 27, 2011 | 11:22 AM
copper's Avatar
copper
The wife's birthday is around the corner. I told her I was going to buy her tools to work on the Porsche, its better than a vacuum cleaner I got the evil eye! Now to teach her how to change the oil!
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
