My First Mod
04-09-2011, 03:17 PM
04-09-2011, 03:43 PM
Gotta be good for at least 10-15hp easy!
04-09-2011, 03:58 PM
Parts SpecialistRennlist Member
5 - its a fact... to get 15 you have to do a little more
04-09-2011, 04:28 PM
Quote:
Originally Posted by
ivangene
Even on the TT? I swear my Turbos are spooling up faster.
Also, props to Wyovino for his detailed step by step instructions. I couldn't have done it without you man.
04-09-2011, 04:53 PM
I just did the same to mine, I can really feel the weight reduction, which you would think has got to add 1 maybe 2 MPH to the top end!
04-09-2011, 06:57 PM
not really measured in hp, its more like you gained a few seconds, due to better power to weight ratios
04-09-2011, 07:26 PM
you loose all the weight savings by putting crap there.... the mod is a wash, but only if you put stuff there.
04-09-2011, 09:08 PM
unless you fill the space with nitrogen.
04-09-2011, 09:17 PM
SSST,
Now you need to change your sig, To one mod so far!
Copper
04-09-2011, 09:21 PM
Certainly a weight reduction. Also if you feel better as a driver, you will go faster. Biggest mod is behind the wheel.
FM
04-09-2011, 09:22 PM
5 more HP if you move the cassette holder outside the car.
04-09-2011, 10:25 PM
copper
SSST,
Copper
Good catch Copper. It doesn't sound very manly though, does it?
04-10-2011, 02:55 AM
Well done. I think with that mod you will be way faster than other TTs Cabs around. You will be the envy of other TTs
