wheels bolts to studs and nuts.
like this? actually he used the wrong bolts, but you guys get the idea.
for me, the dowel rod adds one more step, but thats not worth changing out all my studs.
also, the wheel bolts allow me to change the spacers and the handling bias of my car for the appropriate autox surface.
-td
unless you run a really long stud all the time, wouldn't you have to change the studs if you use a spacer? i'd imagine that would be more of a hassle than changing wheel bolts which is what I do now.
The Penguin King
I'm with TD. Studs are the way to go at the track.
There's a reason that race teams use studs and not lugs...
-td
Yeah - studs are totally easier to deal with than the dowel and bolts for the good reasons himself provided.
As far as the trouble to convert to studs as a downside...are you serious? It's like installing a set of bolts...once!
I've ordered Rennline 80mm - that's 15mm into the hub and 65 protruding. We'll see how those work. I can always go longer because it's no hassle to change them.
Total cost $100
I don't run spacers, but if I ever do I might have to get longer studs.
Total cost $100
have those here already... Oh well
you are looking at 40 mins to remove all the wheels, install the studs with red loctite, drink a beer put wheels back on, drink another beer and admire your work....
You didn't actually *say* you had these earlier though did you.
