wheels bolts to studs and nuts.
I reckon this is a worthwhile mod. I change my wheels a lot (track-street-winter) and I've never liked the bolts much.
Has anyone done this mod? If so please share some detail on how to and where to get the bits.
Thanks!
Thanks!
Why would you want to? Unless you don't have the aluminum screw in dowel/guide. I take off my tires alot switching pads and bleeding brakes in the summer. I use the dowel all the time and changing tires is a snap.
It's just always rubbed me wrong for some reason. I can't really explain why.
Found the info I was looking for over in the racing forum:
https://rennlist.com/forums/racing-a...onversion.html
Which links to the vendor with the tech info:
http://www.apexcompetition.com/Produ.../stud_info.cfm
What length Jeff? And can you use a normal socket or do you travel with a deep socket?
Do you have a local source? I have a request in with ACR but it would be a lot simpler to source locally. I was thinking Drivers Edge.
I also want to talk RS motor mounts.
So many questions. Thanks
Team Owner
I can think of several downsides to using studs. I just don't understand how having to align five studs to install a wheel could ever be easier than having to align a single dowel (hanger) to install a wheel. Also, on my other cars it's not uncommon to have to retighten the nuts after installing wheels and driving a few miles. I've never found a loose bolt on my Porsche.
In any event, you should always check your torque - whether it's bolts or lugs. Losing a wheel on the track is really embarrasing and potentially costly.
-td
http://www.youtube.com/watch?v=S_u-yXag8bg
for me, the dowel rod adds one more step, but thats not worth changing out all my studs.
also, the wheel bolts allow me to change the spacers and the handling bias of my car for the appropriate autox surface.
Team Owner
To each their own. Besides, it's not rocket science - it's a wheel. If you like bolts and a dowel, go for it. I've been tracking for years, and IMO, the studs are easier. [In my experience, if you align with the dowel, you have to roate and hold the wheel to get a bolt aligned and started. You don't with the studs. Also, you have to remove the dowel, keep track of the dowel, etc. It's all extra steps that take time.]
More downsides to using studs is increased difficulty using spacers and making the modification in the first place--I don't know what Porsche's official stance is on doing this.
