What gear ?
#61
Parts Specialist
I never said drive 70 and 4k rpms...
freeway in my area is 55,.... I said 3rd (4th is fine if you wanna putt around) and in no way is that "driving it hard" its actually the opposite... the motor is spinning and IMO it likes to spin fast rather than tug boat along...I come from VW's and you drive a 40 hp motor kinda rapped out..it is easier on the motor to spin fast then to have large torquing action from low rpm's - you dont have to red line it, just keep it spinning, they love it! - (course top speed is like 70 and you have to have big ones to get a 40 horse that fast!)
#62
Exactly right. Every engine runs best when it's operating inside the parameters for which it was designed and is compromised when it isn't, from tractors to airplanes. I'm blown away that this is even debatable.
I note with interest the rarity of M96 engines that failed due to wear on reciprocating parts...
#63
What gear are you in at 55-60mph and answer of 3rd or 4th. What kinda revs is that?
Are you killing it? No...are you creating more wear...yup.
Sings? Another bull**** term made up by people with absolutely zero support for their position. You like how your engine sounds at 4k rpm? Great, have at it, but don't delude yourself into thinking that you're doing your engine any favors.
Tell you what, Quadcammer. Any jackass can call BS; it takes neither expertise nor courage to do it. And I'm sure you aren't a jackass. So since you're the skeptic, why don't we start with you answering all those questions first? That way, I'll know whether I'm being challenged by someone who knows more than I do, or merely by a troll.
These cars are typically rarely used 2nd or 3rd cars. Not to mention production compared to the typical toyota is miniscule. Finally, the majority of owners are not posting on forums. Hence you probably haven't heard much.
Btw, I don't think comparing the reliability of the M64 to the M96 will turn out in your favor.
#64
Now, you are another person spouting off immense BS. So lets address it.
You say This particular engine will last longer and run cleaner and more economically when it's driven harder
prove it. prove how it lasts longer, prove how it runs cleaner, and prove how its more economical (LOL).
then Bear in mind that the ECU is adaptive, and is one of the most sensitive I've ever seen. Try this experiment: Drive your car gently in the city for a week or two, and then take it out and thrash it for a couple of hours on a quiet road or a track. It will feel different afterward, more different than any bolt-on mod you can name (ask me how I know). More responsive, better sounding, less hesitant off-idle and freer revving. Why? Because you allowed it to unlearn the evil fuel mapping it adapted to all that low rpm urban use... mapping that tends to run the engine rich, among other things.
1. How many have you seen? Have you looked at the 996 fuel and timing maps?
2. Better sounding? Care to explain that nonsense?
3. Care to explain how the engine runs rich at low rpm and small throttle openings when the closed loop ecu is designed to keep the car as close to stoich as possible in those conditions?
4. Among other things aye? And what would those be?
finishing up with the most bs of all:
I promise you that the guy who drives his 996 mostly in that pocket isn't being hard on it, he's taking care of it.
Bull****...flat out bull****. Higher rpm=great friction=faster wear. Period, end of sentence. Id love to see if you have any EVIDENCE to the contrary.
2. i've tuned numerous N/A and forced induction cars, from fuel and timing maps to maf curves. I don't deal with 996s, but I'm familiar with the ecu used by the vehicle. Its not exactly revolutionary. The adaptive fuel trims and timing are used to keep a/f stoich and emissions clean at part throttle. At full throttle, the car reverts back to open loop anyway, which provides commanded fuel and timing maps.
3. The engine sounds the same because it is the same. The sound is provided by the exhaust, the engine block material, the firing order, and several other variables. Whether you regularly run the car hard or not has nothing to do with it.
4. Once again, higher rpm=higher friction=more wear. heres a test for you. Run your hand along concrete at 3" per second back and forth. Then do it at 1 inch per second. Which do you think will result in less skin on your hand?
Once again, running the car at wot to redline is not a big deal. it won't cause instant engine damage or catastrophic failure. But you aren't doing your engine any favors. Furthermore, running at high rpms for no reason simply causes additional engine cycles which will eventually cause shorter life for items like the rings and valve springs.
If you want to do it for fun, go ahead. But this is not a needle bearing 356 motor, 2500rpm is not lugging a god damn thing.
#65
Parts Specialist
OK so maybe we just want to emphisize dont under rev.. i looked at the gear/mph/rpm chart and I guess 3rd is a little high for "cruising" but I think it started as a bit of fun and turned into something more.....
2500 rpm is about minimum for me - yes I tend to run it a little faster as I have not grown up yet and pray I wont be all grown up too soon... - turning my "debate" switch - OFF -
#66
Parts Specialist
IF you use lower pressue the 1 inch a second can create less wear...there is some point where presure and friction and heat and waer have a sweet spot and some area where the percent is not sufficiently differant and some point where its a big frickin deal...
RE carbon build up... I have seen Tips and 6 speed pistons and almost without exception you can tell which is which from across the room.... same motor, same firing order same ECU... differant RPM usage
whoops I thought I was in debate -OFF- mode
#67
Ok, so one piston has a very light coating of carbon...so what? This is not exactly going to harm anything.
#68
Parts Specialist
+1 on the RPM's we can put that horse in the ground....
carbon is not one piston, I mean ALL pistons on tips -vs- 6 speeds, they tend to have significantly more carbon build up... and on close to zero clearance motor the added carbon can make contact with the head, so yes, carbon is an issue at some point. It also effects heat disapation to some degree I would suspect. Having the choice to use carboned up pistons or clean tops I doubt you would put the carbon ones in there for some reason or another which is the same as saying you dont think they are as good... maybe not bad, but not as good....so tips run lower rpm's and have more carbon deposits = cant be better = lower rpm cant be better
there I win
there I win
#69
I appreciate the effort you put into your response, but you're really just making counterclaims rather than making me smarter. So we'll agree to disagree.
I've owned two dozen cars and raced a little. I've also consulted to two car companies. But I'm not a mechanic or an engineer. I can only make calls on the basis of my aggregated observations and what I've learned along the way, just as you are doing. And here's what I think:
- Only an electric motor operates at the same efficiency all the time. Reciprocating engines don't. I drive my diesel tractor differently than I drive my 996, because the engines were built to operate differently. I see no dividend in making a motor do something its designers didn't make a priority of, even i fit can. These guys had a specific 'typical' use in mind when they made decisions about reciprocating parts.
- My confidence about efficiency is based partly on two things: I keep religious track of mileage (I think this is a great indication of how well an engine is running), and I pay close attention to my tailpipes (following an issue with my Dinan Z3).
- This engine doesn't suffer much from wear to reciprocating parts (most don't. I was recently in a limo that had over a million kilometers on it). Whereas it does suffer from lots of things that may - may - be related to engines being used too little and too gently. That's the risk I choose to take.
- I have to disagree that carbon is not an issue, having just spent a few thousand dollars rebuilding the top end of my wife's MINI. It's a long story and not really all that relevant, but believe me. Carbon is not something to dismiss, even in a modern engine.
I don't know why this issue makes you so hostile, but you are absolutely free to use your car as you see fit as far as I'm concerned. Until someone educates me otherwise - that's educates, not berates - I'm going to remain a member of the drive-it-like-you-stole-it tribe, which is pretty large and seems, anecdotally at least, to have pretty trouble free cars.
#70
I just want to say that I agree with everyone on this issue.
#72
When I drove my C4S across canada...I had the cruise on in 6th doing 115-120KPH. I was getting 7.8L/100Kms through flat, boring Saskatchewan! That's MUCH better than Porsche's own numbers.
Even now...doing long trip on cruise at 120-125....I get under 10L/100Kms...and that's also better than Porsche's number.
I could do pretty close to 600Kms to a tank. The EPA rating for my car says I should only get 441Kms.
City driving....and especially in the winter....my fuel economy SUCKS *****. In the winter I've been getting 300Kms to a tank. The computer tells me I'm getting 18.4L/100Kms. Which is WORST than Porsche's and EPAs numbers.
So in the end, I think it all balances out.
#73
I guess I do "inspired" driving, and this winter there has been a lot of "TC OFF"-driving, both around town and elsewhere. I've usually been between 22-23L/100kms.
And 98 unleaded costs 2,56 usd / litre...
#74
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
FWIW, I feel your pain. The price difference between regular and premium in Canada runs about 15 cents a litre, which translates to 57 cents per US gallon. Those guys don't know how lucky they are...
#75
Octane is easy: Fill whatever is written in the manual. Porsche says 98 for my 996 so that's what I'm filling. Any more than that without a remap is just as silly as screaming down the highway at 4500 rpm
