Mirror reverse trick?
Hey guys,
Somewhere on the interweb I read that if I set my seat memory with the (manual) transmission in reverse, the passenger side mirror will automatically lower when I put the car in reverse.
I tried it, but it didn't work.![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Is this folklore, or did I do something wrong?
Cheers,
-- Mike
Cheers,
-- Mike
Swimnbud (04-18-2024)
The following 2 users liked this post by rajeshr:
paddlefoot64 (05-21-2021),
Yup. Here's the steps I'm following.
1. Get in the car.
2. Turn the key on (don't start the engine, though, 'cuz I ain't going anywhere right this second).
3. Put the shift lever in reverse.
4. Fiddle with the seats and mirrors until they're where I want them.
5. Set memory position 1 for the seats by holding down the M and 1 buttons.
6. Take the car out of reverse.
Now, when I put the car in reverse, the mirror should go down ... right?
Cheers,
-- Mike
1. Get in the car.
Cheers,
-- Mike
The following 3 users liked this post by mikehelms:
You have a memory seat?!
The following 3 users liked this post by Chaos:
1. Get in the car.
Cheers,
-- Mike
1. Get in the car.
Cheers,
-- Mike
I've always set mine with the car running so that seems to be the only difference between what you wrote and what I do to get mine to work.
If you follow those steps and its still not working your reverse switch on the transmission is likely bad. You can confirm this by having someone check that your reverse lights come on when you put it in reverse. The switch is inexpensive and very easy to replace if this turns out to be your problem.
-Shawn
-Shawn
Mine works great. It is one of those cool little things that I love about the 996.
Now if I can just get my darn rain sensor to work properly... I have a bad board, I think. Hey, I guess that means that my intermittent wipers work intermittently...
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
My side mirror adjustment works when the three different memory bottons are pushed. It does not toggle down when in reverse. My manual says the dealer needs to activate this "reverse" feature for you.
1. Get in the car.
Cheers,
-- Mike
1. Get in the car.
Cheers,
-- Mike
