ROW M030 Installed
Just wanted to post some photos of my car with the ROW M030 Installed. Just had the car aligned yesterday, unfortunately it was pouring so I just drove it for the alignment and than straight back home. But so far so good... Also had my console painted to match the exterior. Not its time to enjoy the car for the season!
I'll have to see if I can find any before pics, but the car sat much higher in the front compared to the rear with the stock suspension.
I did do the install myself, the fronts were a bit of a pain since it is a C4 and the halfshafts limit the amount of play, but once I picked up a balljoint separator it made the job a lot easier. The rears were very straight forward and gave me no problems at all.
I just did the bars/bushings,car seems lower. PM me the details on your center console,looks great.
What is your front and rear camber and toe set at? Just had mine aligned too. -0.3 front camber and -1.4 rear camber. Can't remember toe. I was hoping for more front camber.
I did a bunch of work yesterday and didn't even look through all of the alignment specs, I know he pretty much maxed out the camber in the front, which I confirmed by checking the position of the strut but I will try to check tonight for you though.
