Cardan Shaft - '03 C4S
I didn't see a part # on the Porsche part.
Sorry, nothing positive to report, according to my mechanic it doesn't fit, the holes are off spec. He did recommend me a 2WD conversion instead of buying a new shaft ;-).
I wish there were an index of all guibos so that we could find one that fits...I d'ont fancy spending 600$ on a new shaft when I just need a flex disc
Resurrecting this thread....
I am replacing mine in the next day or so. 2003 C4S with 85k miles. I've got a increasing driveline vibration that's constant, this flex disk seems to be the culprit.
I'm looking for photos or information from those who have done this. What's involved, location exactly etc etc.
Thanks in advance.
Thanks in advance.
Is this what you are looking for?
http://www.dragtimes.com/parts/Flex-...638366323.html
I'm looking for install instructions photos tips etc
I found these instructions over in Rentech from JEFF IN PA "Not overly complicated; remove the plastic underbody shields, support the transmission and remove the trans mount support bolts. Remove the trans support metal brace. At this point you should be able to see the driveshaft flex disc, remove the bolts in the disc and pull the driveshaft out while putting something under the front diff to catch any oil that may drip."
