I decided to clean out my radiators this afternoon. I had never done it, although I had seen photos of the crap that can accumulate in there. Everything was pretty easy. When I got the ducts off and got to the radiators, I was truly shocked. There was so much crap in there, I can't believe my car hasn't overheated! There were leaves, there was dirt, bugs, cigarette butts, a piece of wood, and even the label from an Aquafina water bottle! It was disgusting! I'm so happy that's done. I won't wait this long again to clean them out.
A great & easy way to keep that area clean now that you've done the hardest and biggest clean-up, is by using your leaf blower. Just before washing (dry) and after washing (wet), use your leaf blower to blow out any debris. Stuff will come flying out each time. Easy to do.
Prior to winter hibernation, I duct tape a 2 foot section of 3/4 inch tubing to my shop vac., and with a flashlight, I can vacuum up any remaining debris.
Also a great way to 95% dry the car, wheels, the wheel's barrels, cross drilled rotors & calipers, joints and seals. Less touching=less micro scratches.
There's an excellent DIY guide on renntech.org. It even has a video. I followed that to remove my bumper and ducts. The hardest part of the bumper removal was getting the plastic wheel wells out from behind the bumper to reach one of the screws behind the side marker. Once that was done on each side, it came off easily. Once I got it apart and got down to the radiators, huge amounts of dirt fell out onto the garage floor. I then used a shop vac with a brush head to gently remove all the debris that was stuck on the radiators.
Nice job Dennis. I did the same last year and couldn't believe the amount of crud ingested, undetected before cleaning. Great reminder for those who haven't done this.
I used that diy, but was led astray. There seem to be two radiators on each side of the car, one stacked behind the other. The guide never said to depressurize the coolant, so I happily went and removed the front radiator, causing pressurized coolant to spew into the garage. Had to run to the engine & depressurize the tank, but that was not a fun experience.
Maybe it was common sense to depressurize it, but I'm surprised the guide never mentioned it. Did you have this issue?
You don't need to disconnect the fluidic connections to the radiator to clean things. You just disconnect the screws/clips that hold the two together and you can move them apart to get in and clean things up.
Yup. When I did my Boxster a few years ago that part of the job was a real PITA. Especially trying to get that GD screw back in. Seems to have taken 10 minutes and lots swearing as I recall and it's the only thing making me reluctant to tackle it this weekend on the C4S.
The other thing I ran into was one of the retainer pins for the wheel liner broke so I had to run to the dealer for a replacement. Fortunately, I was on good terms with the parts guy so he just gave them to me, meaning I have no idea how much they'd cost if I broke one now.
