996 Forum 1999-2005
GT Key programming- didn't come with code tag...
Old 02-18-2011, 09:25 AM
PAULUNM
PAULUNM's Avatar
Originally Posted by Gert
The CGT key head always come with a code.
In fact, the CGT used the same alarm system as the 996/986.
Gert-
Thank you for the info, that's what I thought. Would you happen to have something from the CGT manual that shows the same programming sequence as the 996?
Old 02-18-2011, 10:40 AM
Gert
Gert's Avatar
Just look in the PET, you will see that the part nr of the US/CGT alarm is the same as the US/996.
The code card that comes with the CGT key also has a 996 part nr, the same part nr as a 996 replacement key head.
Old 02-18-2011, 11:01 AM
PAULUNM
PAULUNM's Avatar
Excellent, thank you.
I found the attached document- am I reading this correctly in that you can determine the key code for a key with an unknown key code? (hope that makes sense...)
File Type: pdf
Old 02-18-2011, 01:48 PM
fpb111
fpb111's Avatar
This still asks for the 24 digit learning code for the new transmitter.
Old 02-19-2011, 11:47 PM
fpb111
fpb111's Avatar
What was/is the outcome?
Old 02-20-2011, 02:40 AM
PAULUNM
PAULUNM's Avatar
I called Suncoast- they say they are pretty sure the CGT key comes with the code tag.
So I told Sunset that, they ordered a new key, and I shipped the tagless key back to them.
Now, if the replacement key doesn't have a tag...
I'll let you all know what happens. I'd really like to have the CGT head with NEW internals. Seems silly to put my 8 year old electronics into a new CGT key that comes with new internals...
Quick Reply: GT Key programming- didn't come with code tag...
